Products
ReliaMark Offers Stainless Steel Shaft Collars
Melissa Larson | May 4, 2015
ReliaMark, distributed exclusively by Kaman Industrial Technologies Corp., has announced the release of its stainless steel shaft collars. Now, in addition to its existing line of ReliaMark stainless steel ball bearings, corrosion-resistant mounted units and stainless steel chain, the company offers an additional product suited for washdown applications and other corrosive environments.
ReliaMark stainless steel collars are available off-the-shelf in over 100 of the most common sizes, ranging in 1⁄8 in. to 3 in. bore sizes. Manufactured in T304 stainless steel, the ReliaMark line includes solid set-screw collars, one-piece (single-split) and two-piece (double-split) collars with socket head cap screws.
ReliaMark stainless steel shaft collars are manufactured to meet industry standards for use in a wide range of washdown applications and are effective on both hard and soft shafts. Bore tolerances range from +.004/+.000 for bores up to 3 in.
Melissa Larson
