Maintenance News Products
Milwaukee Tool Cordless, Self-Priming M18 Transfer Pump Meets Water-Removal Challenges
Jane Alexander | October 10, 2016
Wisconsin-based Milwaukee Tool (Milwaukee) says the company’s recently introduced M18 Transfer Pump for water removal is the first self-priming, cordless pump of its type.
Completely self-priming, it’s designed with a flexible impeller that, once turned on, starts pumping water instantly from inlet to outlet without the need for additional priming assistance. This flexible impeller also helps create a powerful pressure difference that can produce an 18-ft. lift.
With a capacity of 480 GPH (gal. per hr.) and head height of 75 ft., the M18 Transfer Pump is suitable for a variety of water-removal challenges. Equipped with the manufacturer’s advanced REDLINK Intelligence system, these units are protected against dry pumping by their ability to switch themselves off when an application is complete. This capability helps protect the motor, thus maximizing service life and allowing users to perform other tasks without worrying about damaging the pump.
The battery connects to the pump in a splash-proof compartment on the back of the unit. This compartment is large enough to fit all M18 battery packs. In addition, a clear viewing window provides better visibility to the impeller, allowing the user to quickly troubleshoot blockages or other issues.
The M18 Transfer Pump comes with two ¾-in. brass threads to fit all major brands of hose connections. It’s offered as a bare tool (pump alone) or as a kit (which includes an M18 REDLITHIUM XC Extended Capacity Battery and M18 & M12 Multi-Voltage Charger).
For more information, CLICK HERE.
Jane Alexander
