September/October
Grease Basics Part II: Selection & Applications
EP Editorial Staff | September 1, 2009
rgb1020greasebasicscorrect
Now that you have a solid understanding of what grease is, it’s time to refresh yourself on which type of product is best for the job.
Be Kind To Your Bearings & Other Critical Components
This article is a continuation of a discussion that was featured in the July/August 2009 issue of Lubrication Management & Technology. While grease is used in a wide range of applications, this installment will focus on bearings (primarily rolling element).
Part I of this article provided a basic introduction to grease, with discussions of composition, types, properties and evaluation tests. Part II will focus on the correct grease for the application and some of the key criteria in the selection process, including compatibility, amount to be added and relubrication frequency.
Table I, compiled by the National Lubricating Grease Institute (NLGI), illustrates the consumption of grease in North America in 2008. This table, which exceeds 100% because of rounding, illustrates that more than 60% of greases produced in North America in 2008 were lithium-based soaps with the use of lithium complex grease exceeding that of simple lithium soaps. Complex lithium soaps are the fastest growing thickener type worldwide. Simple lithium soaps accounted for 58% of the worldwide production in 2008, while lithium complex accounted for 15%. Simple lithium soaps are more widely used because of their lower costs, but lithium complex greases, because of their inherently better properties, are faster growing.
Table 1. 2008 North American Consumption of Grease by Type (courtesy NGLI)
Thickener Type %
Straight Lithium 30
Lithium Complex 36
Calcium Soaps 10
Aluminum Soaps 9
Polyurea 6
Organophilic Clay 6
Sodium & Other Soaps 2
Other Non-Soaps 2
The general rule is to use oil for lubrication, if possible, because of the ability to clean and cool oil versus doing so with grease. There are, however, many applications where oil use is not possible or practical. Table II lists a few of the industrial and mining components utilizing grease as a lubricant. Rolling bearings are a major component lubricated with grease—in fact, most of them are.
Table II. Industrial and Mining Components that Utilize Grease
Industrial Mining
Bearings
(rolling element general)
Bearings (rolling element)
Bearings
(electric motor)
Bearings (Journal)
Bearings (Journal) Gears
Couplings Slides
Gears Linkages
Slides Chains
Linkages Pins
Chains Buckets
Wheel Hubs
Grease selection
The major criteria in selecting a grease type for the application are the thickener type, base oil viscosity and NLGI Grade. Table III denotes general guidelines for grease selection based on bearing speed.
Table III. General Guidelines for Grease Selection Based on Bearing Speed
Application Viscosity Consistency Oil Release
Fast Thin Stiff High
Slow Thick Soft Low
As stated in Part I, oil is the lubricant in a grease—and the most important property of an oil is viscosity. Therefore, the correct viscosity must be selected for the application. The grease manufacturer provides this information. Although viscosity of a grease is not usually listed on its container, it is listed on the product data sheet. Table IV shows viscosity selection based on application.
Table IV. Correct Viscosity Selection for an Application
Viscosity Application
ISO 100 Electric motors and high-speed bearings > 3600 rpm
ISO 150 & 220 Multipurpose grease operating at moderate speeds
ISO 460 High loads and good water resistance
ISO 680* High-speed couplings
ISO 1500 Very low speed, high loads and good water resistance
ISO 3200* High-speed couplings
*Coupling grease can have ISO 680 or ISO 3200
depending on the manufacturer.
The thickener type is a very important consideration in grease selection. The following grease properties are directly related to the type of thickener:
  • Amount determines consistency
  • Shear stability
  • Oxidation resistance
  • Water resistance
  • Dropping point
  • Compatibility
  • Oil separation
  • Cost
Table V illustrates the major thickener types and their common uses.
Table V. Major Thicken Types & Their Common Uses
Thickener Type Application
Straight Lithium Versatile and less expensive than the Li Complex. Should not be used over 275 F.
Lithium Complex Most versatile thickener for wide variety of industrial and automotive applications. Used up to 350 F. Does not have H1 approval and is not used as food grade grease.
Aluminum Complex Good high-temperature and water-resistant properties. Used in steel and paper mills. Most common food grade thickener with H1 approval. Used up to 350 F.
Polyurea Excellent oxidative resistance because of non-metallic thickener. Grease of choice for electric motors and sealed-for-life applications. Use up to 350 F.
Organophilic clay Non-melt resulting in good high-temperature properties along with H1 approval for food grade. Used in oven conveyers. Used up to 350 F.
Calcium Complex Good water resistance and H1 approval. Used in steel and paper mills. Also used in food plants. Used up to 350 F.
Calcium Sulfonate Very good inherent corrosion resistance and high EP along with H1 approval, but expensive because of high thickener content. Used in food grade, corrosive and high-load environments. Used up to 350 F.
Sodium Inexpensive and used where good adhesion and corrosion protection required. Cannot be used in presence of water and limited to 250 F.
Many plants have too many types of grease and should consolidate down to just a few. Table IV reflects a practical consolidation option to consider.
Table VI. A Practical Grease-Consolidation Option
Application Grease Type
General Purpose Lithium Complex EP
Electric Motors Polyurea
Couplings Lithium/Polymer with same density as base oil specially designed to avoid separation due to centrifugal forces
Food Grade Aluminum Complex
High Temperature Clay
Eighty percent of a facility’s applications can be addressed with the first three greases listed in Table VI. The remaining 20% are for specific applications such as food grade, high-temperature and other specialized applications.
Incompatibility is a major issue when mixing greases—something that can result from having too many types of grease in a plant. When changing grease thickener types in an application, always consult your lubricant supplier on the compatibility of a proposed product with one that’s being replaced. This is of the utmost importance as incompatible greases will usually lead to a softening of the thickener resulting in oil being released; that chain of events can result in equipment failure. If your supplier is unsure of the compatibility, ask that an ASTM 6185 compatibility test be performed.
The following greases are the most incompatible in this order: barium, clay, aluminum and conventional polyurea. Be very careful about using published compatibility tables when making a decision to change thickener types. When in doubt, always consult your lubricant supplier.
The most common NLGI grade used is #2, but there are situations where a more- or less-consistent grease should be used. Table VII reflects guidelines for the selection of NLGI grades.
Table VII. Guidelines for Selection of NLGI Grade Grease
NLGI Grade Application Consistency
6 Slow-moving journal bearings Block
5 Low-speed journal bearings Very stiff
4 Very high speed and low load Stiff
3 High-speed rolling element bearings. Typically ball bearings. Medium
2 Most common grade for all rolling element bearing types Medium soft
1 Centralized lubrication systems and low temperatures Soft
0 Centralized lubrication systems Very soft
00 Enclosed gears Semifluid
000 Enclosed gears Fluid
Grease application
Once the correct grease has been selected, it has to be applied properly with the right amount at the right frequency. There are many different options for doing this. Ideally, a small amount should be applied more frequently. This is the advantage of using an automated system, such as single-point lubricators and centralized grease systems. The most common application system, though, is still the manual grease gun—the device on which this particular article focuses. (Automated systems are beyond the scope of this article. Moreover, the remaining discussion will focus only on bearings—primarily rolling element.)
Amount…
Journal bearings are not usually grease lubricated and there is a speed limitation of 200-400 ft./min. The bearings have wide, deep axial grooves, extending about 80% along the bearing. The grease is introduced along the groove which is 90 to 180 degrees away from the load zone. When greasing, completely displace the old grease by observing fresh grease from the bearing. Normally, slow-moving journal bearings don’t have to be greased frequently unless they are exposed to a high level of contaminants.
Rolling element bearings require calculated lubrication amounts for an effective greasing program—unless they are in a contaminated environment where total grease displacement is required. This certainly doesn’t apply to electric motor bearings, where over-greasing is very common. Correct greasing procedures for electric motors, of which there are many opinions, will be discussed in a future article.
Lubricators should have specific instructions in work orders on the exact amount of grease to add to a bearing. This should not be left up to the oiler, but instead developed by someone in the organization through proper techniques. Grease guns need to be calibrated on the amount per shot put out by the grease gun. The following formulae are used to calculate—by weight—the correct amount of grease to apply to a rolling bearing.
cutawayweb
Since most bearing dimensions are expressed in millimeters (mm) the following is a more usual formula:
G (ounces) = 0.00018 × DB (mm)
Take, for example, a 150 hp motor with a 313 size bearing that has the following dimensions:
65 mm bore
140 mm OD
33 mm width
In this example, utilizing the foregoing formula, we calculate G = 0.00018 × 140 × 33 = 0.83 ounces of grease required for the bearing.
The next step is to calculate the number of shots per ounce the grease gun delivers. This can be done by using a postage scale and weighing out 10 shots of grease and calculating ounces per shot and then equating this to shots per ounces. Assume we had 0.5 ounces in 10 shots. This equates to 0.05 ounces per shot, which converts to 20 shots per ounce for that particular gun. Another method not as accurate is to fill a 35-mm film canister and count the number of shots. This is approximately 1 ounce of grease. Therefore, 0.83 ounces required for the bearing using a 20-shot-per-ounce gun results in applying 0.83 × 20 = 17 shots.
Be sure to calibrate all of your grease guns and use one particular type per application. For example, when greasing electric motors, try to use the same type of gun for all motors. Meters can be purchased to measure the exact amount of grease in ounces, grams, cubic inches and cubic centimeters. One company calculated the number of shots for all of its electric motors by horsepower and constructed a table that is put on the grease guns relating the amount of shots required by horsepower of motor.
Relubrication frequency…
Once we have calculated the right amount for a rolling element bearing, we then have to establish lubrication frequencies for that bearing. The following is a formula used to establish initial frequency guidelines.
1019forumlaweb
t = K [ 14,000,000 _ 4d ] n d
t = relubrication interval in hours
d = bearing bore diameter, mm
n = speed, rpm
K = 1 for spherical or tapered roller bearings
K = 5 for cylindrical or needle bearings
K = 10 for radial ball bearings
The above data is used as a starting point. The following adjustments need to be considered.
  • Temperature—For example, every 27 F degree increase over 160 F requires the frequency to be cut in half.
  • Position—Vertical bearings need to be greased twice as frequently.
  • Vibration—Higher vibration readings require more frequent greasing.
  • Contamination—Higher contamination requires more frequent greasing.
Keep in mind that there are precise correction factors with these variables beyond the scope of this article. Such correction factors can be obtained from bearing manufacturers.
Removing the mystery
This article has been written to help take the mystery out of the topic of grease and to give you some techniques to improve the selection and application of grease in your facility. While it may be one of the oldest lubricants known to man, grease continues to be a vital part of any lubrication program. That’s because the majority of bearings in a typical industrial plant are grease lubricated.
The importance of selecting the correct grease and applying it properly—both in amount and frequency—cannot be overstated. These activities are key factors in a world-class lubrication program. Getting them right is crucial in improving (and ensuring) the reliability of the equipment within your operations. LMT
Contributing Editor Ray Thibault is based in Cypress (Houston), TX. An STLE-Certified Lubrication Specialist and Oil Monitoring Analyst, he conducts extensive training in a number of industries. Telephone: (281) 257-1526.
