May
EP Editorial Staff | May 16, 2011
0511market1Protection For Hydraulic Fittings
The Brennan Black® coating from Brennan Industries protects against rust and corrosion in hydraulic fittings and adapters. The proprietary Bi-LENE® coating is a blend of fluoropolymer, engineered plastics and selected corrosion inhibitors tailored to provide specific properties such as low friction, strong adhesion and resistance to wear and abrasion. According to the company, the coating resists corrosion past 1600 hours of exposure and works in temperatures from -420 to +500 F.
Brennan Industries, Inc.
Cleveland, OH
0511market2Wireless Shaft-Alignment TooL
VibrAlign’s Fixturlaser GO Pro, a wireless shaft-alignment tool, features an adaptive and time-saving user interface that guides users through the alignment process. If an alignment is out of tolerance, the tool first suggests how to correct it vertically, such as by showing the shims by size required to achieve a precision state. In a horizontal adjustment, live values are displayed throughout the entire process, with no re-measurements required.
VibrAlign, Inc.
Richmond, VA
Hydraulic-Hose Condition-Monitoring System
Eaton says that its LifeSense™ hose can report imminent hose-assembly failure via real-time monitoring of high-pressure hose assemblies used in hydraulic systems. Capable of tracking the health of each hose assembly in a system, it detects when a hose is nearing the end of its useful life and alerts the user so the assembly can be replaced.
Eaton Corp.
Eden Prairie, MN
Portable Ultrasonic Flowmeter
KROHNE’s Optisonic 6400 portable ultrasonic flowmeter for liquids measures flow velocity, current volumetric flow and various diagnostic values. Users simply attach the sensor rail to the pipe, plug cables into the handheld electronics, set up parameters and begin reading flow results. The device is powered by an integrated battery with 14 hours running time or line-powered by a supplied adapter.
KROHNE, Inc.
Peabody, MA
Compact, Eco-Friendly Gas Insulated Switchgear
ABB’s latest generation 245kV ELK-14 series of Gas Insulated Switchgear (GIS) has a footprint 40% smaller than conventional designs and uses 20% less SF6 gas than the previous generation. Its compact design also allows the unit to be delivered as a completely assembled bay, reducing installation time. The bays feature single-phase isolation, and the systems have been designed for a rated voltage of 253 kV and rated currents of up to 3150 Amperes.
ABB
Cary, NC
0511market3Flexible, Heavy-Duty Speed Reducer
Baldor’s Motorized Torque-Arm II (MTA) is a right-angle shaft-mounted speed reducer with a three-piece coupled NEMA C-face motor input. Its compact, flexible design allows multiple mounting positions. A choice of 12 helical gear-reduction ratios and three case sizes help deliver speed reductions from 18:1 to 75:1 for class 2 applications from 3 HP to 75 HP. According to the manufacturer, the MTA’s heavy-duty AGMA-rated design offers nearly twice the bearing life versus competitors’ European DIN standard designs. Premium HNBR oil seals with excluder seal technology give extra protection against contaminants.
Baldor Electric Co.
A Member of the ABB Group
Fort Smith, AR
CIMM Certification Program Becomes CMRT Certification
After nearly two years of work on the body of knowledge and the process and procedures for administering the program, the Society for Maintenance and Reliability Professionals Certifying Organization (SMRPCO) has announced its relaunch of the Certified Industrial Maintenance Mechanic (CIMM) program as the Certified Maintenance and Reliability Technician (CMRT) program. According to the SMRPCO, this new certification can be a stepping-stone for candidates who hope someday to become Certified Maintenance and Reliability Professionals (CMRPs). For more information, visit www.smrp.com.
SMRPCO
McLean, VA
0511market4Efficient SS Horizontal End Suction Pumps
Grundfos says its new CRN-H and CRNE-H stainless steel horizontal end suc-tion pumps have been designed for a variety of applications, including washing and cleaning, water treatment, chemical, pulp and paper and more. Among their notable features is the CRN-H plug ‘n play retrofit capability that lets it be bolted directly into the piping and pump case footprint of a traditional ANSI unit. The company also says these pumps can reduce energy costs up to 80%.
Grundfos Pumps Corp.
Olathe, KS
0511market5Remote Valve Operator
Smith Flow Control’s Flexi-Drive valve actuator allows remote operation of valves in hard-to-reach or dangerous areas. It attaches to the host valve with no modifications needed. A flexible linear drive cable connects the valve to a handwheel up to 200 feet away and accommodates up to 540 degrees of bends. The system is completely sealed and permanently lubricated for maintenance-free operation; can operate completely submerged in water up to 50 feet deep; and withstands temperatures from -65 to +400 F.
Smith Flow Control, Ltd.
Erlanger, KY
Professional-Grade Hand Tools
DeWalt’s recently launched line of hand tools (a first for the company) features more than 100 professional-grade products, including utility knives, pliers, wrenches, tape measures, hammers, saws, toolboxes and more. The company has tested them on jobsites across the country and incorporated feedback from users to improve the quality of the line. Each product comes with a limited lifetime warranty and support from DeWalt’s service network.
DeWalt Industrial Tool Co.
Baltimore, MD
0511market6Signal-Conditioner And Relay Interfaces
WAGO’s Interface Adapter provides JUMPFLEX® Signal Conditioners and Relays with a tool-free interface to the WAGO-I/O-SYSTEM and other PLC interfaces. They capture analog/digital sig-nals for eight combined JUMPFLEX modules. This, the company says, makes them ideal for equipment that requires large amounts of input/output signals. They help cut wiring errors in both field and control levels.
WAGO Corp.
Germantown, WI
0511market7Quick Belt-Change Conveyor Supports
Cantilever stand mounts from Dorner Manufacturing support conveyors from one side, which opens the other side for quick access and belt changes. The design allows the belts to slide off without  the need to remove stands. Only one technician is required  to complete the belt changeout. These time-saving supports are engineered to work with Dorner’s 2200 and 3200 Series conveyors.
Hartland, WI
