September
Technology Showcase: Mechanical & Hydraulic Equipment
EP Editorial Staff | September 21, 2012
0912techshowspectronicsAccurately Pinpoint Sources Of
Fluid Leaks
Spectronics has introduced the OPK-341 Industrial Leak Detection Kit that the company says can pinpoint the exact source of fluid leaks in hydraulic equipment, compressors, engines, gearboxes, fuel and other synthetic and petroleum-using industrial systems. The kit’s core is the OPTIMAX™ 3000, a cordless, super-powerful, rechargeable blue-light LED inspection flashlight. Fifteen times brighter than regular LED flashlights, it has an inspection range of up to 20’ (6.1 m). The kit also includes a 16 oz. bottle of patented OIL-GLO™ 44 concentrated fluorescent oil dye that’s compatible with all synthetic and petroleum-based fluids. When a leaking industrial system is scanned with the OPTIMAX™ 3000 flashlight, the dye glows brightly to reveal the precise location of the problem. An 8 oz. spray bottle of GLO-AWAY™ dye cleaner, smart AC and DC chargers, dye treatment tags and fluorescence-enhancing glasses round out the kit that comes in its own rugged carrying case.
Spectronics Corp.
Westbury, NY
For more info, enter 08 at www.MT-freeinfo.com
0912techshowhaweSpace-Saving Directional Proportional Spool Valves
HAWE offers proportional spool valves for both fixed (PSL) and variable (PSV) displacement systems. Made of steel, these tough, small-footprint units can ensure the type of high-cutting force and reliable operation that’s essen-tial for roadheaders, longwall shearers and microtunnel boring machines. According to the manufacturer, its PSL and PSV units operate efficiently in mid-pressure ranges, but easily manage high-pressure surges that occur when equipment encounters rocks and rough terrain. Their high degree of proportional control allows precise positioning and significant maneuverability. The size of these valves saves space in the overall design of the machine and their modularity simplifies servicing. HAWE’s compact PSL directional proportional spool valve is designated for use in areas with explosive gas, vapor, aerosol and air mixtures and dusts or mists. Certifications according to ATEX, IEC, MSHA and MA are available on request.
HAWE North America, Inc.
Charlotte, NC
For more info, enter 09 at www.MT-freeinfo.com
New Zinc-Free Hydraulic Fluid Delivers A Range Of Benefits
Shell Lubricants has introduced Shell Tellus S3 M, a new hydraulic fluid that uses unique, advanced, zinc-free anti-wear technology to deliver improved pump protection, enhanced system efficiency and up to twice the life of Shell’s previous zinc-free product. It’s suited for use in factory-based industrial hydraulic applications and severe-duty, extended-operation applications, as well as in mobile and outdoor applications in climates with limited temperature variations. According to the manufacturer, the low aquatic toxicity of this product reduces its environmental impact in the event of a spill and helps operators better manage the environmental impact of their processes. For example, using it in equipment suffering from leaks or frequent hose bursts and loss of fluid can help reduce the risk of zinc and other heavy metals entering a plant’s wastewater. Available in five ISO viscosity grades, Shell Tellus S3 M meets the requirements of a number of OEM specifications, including, among others, Husky (ISO VG 46), Parker Hannifin HF-0, HF-1, HF-2, and Eaton 694. It also meets standards ISO 11158 HM fluids, AFNOR NF-E 48-603, ASTM D6158 (HM mineral oils), DIN 51524-2 (HLP oils) and Swedish Standard SS 15 54 34 AM.
Shell Lubricants
Houston, TX
For more info, enter 10 at www.MT-freeinfo.com
0912techshowherculesHeavy-Equipment Seals, Replacement Parts And Hydraulic Cylinders
Hercules Sealing Products is a North American distributor of hydraulic and pneumatic seals, seal kits and cylinders. It also offers premium replacement engine and transmission gasket kits for popular off-road and marine applications. According to the company, Hercules publishes the largest single-source catalog of seals, replacement parts and technical information in the industry (35,000 individual products). Replacement seals, seal kits and hydraulic cylinders are stocked for manufacturers like Caterpillar, J.I. Case, John Deere, Komatsu, Nissan and Toyota, to name just a few. Hercules is also an authorized distributor of hydraulic cylinders manufactured by Parker, Commercial, Custom Hoists and Hyco. To serve the Canadian market, it sells products in Montreal and Toronto through Hercules Sealing Products Canada, a wholly owned subsidiary.
Clearwater, FL
For more info, enter 11 at www.MT-freeinfo.com
