November/December
The Corporate Report: Des-Case Corporation
EP Editorial Staff | December 5, 2012
Des-Case understands the importance of fluid cleanliness and the role it plays in helping equipment investments last longer. For more than 25 years, we’ve pioneered solutions to help maintain lubricant quality specific to your applications. Featuring designs unparalleled in the marketplace, Des-Case products are used wherever lubricant life and performance are essential to daily operations.
Industry-Leading Manufacturer of Desiccant Breathers
  • Continuous innovation.We invented the desiccant breather and continue to design new innovations.
  • The widest range of high-value solutions. From small gearboxes to large hydraulic systems and storage tanks, Des-Case breathers are engineered to last and match with your specific needs.
A Full Line of Fluid-Handling Products
  • Easily customizable.Des-Case filtration systems can be easily configured to your exact needs.  Larger systems are also designed to your specs.
  • Rugged designs/thousands of options.Our systems incorporate smart technology to make contaminant filtration a simple task that requires less equipment and labor, while reducing system contamination.
Lubrication TransformationSMPutting Best Practices Into Practice
  • Consulting services and in-depth training. We specialize in helping companies pin-point lubrication issues and identify effective ways to address them, including plant surveys, one-day best-practice overviews and intensive training classes with ICML certification options.
  • Highly knowledgeable team. Our Lubrication Transformation program is managed by lubrication engineers with years of in-plant experience. Visit descase.com to learn more about how we can help you take the next step in your best-practice journey.
Whenever you need contamination control, you can count on Des-Case to provide the right products and services to keep you up and running.
1112descaselogo
675 N. Main Street
Goodlettsville, TN 37072
Ph: 615.672.8800
www.des-case.com
