Lubricant Inspection Pod from Luneta
Greg Pietras | January 14, 2014
The Condition Monitoring Pod (CMP) from Luneta is a multi-parameter device for expanding daily lubricant inspections. The CMP is a visible inspection window providing a method of inspecting machine health without the need for laboratory analysis. It includes a built-in oil sampling port, an easy-to-remove magnetic plug, a corrosion/ varnish inspection probe, and quick lubricant access point for syringe sampling. Best applications include gearboxes, bearing oil sumps, hydraulic reservoirs, compressor oil reservoirs, turbine-generator main oil tanks and paper machine central reservoirs.
Luneta, LLC
Jenks, OK
