Oil-Skimmer Selection Guide
EP Editorial Staff | February 26, 2014
Abanaki recently launched its new, interactive oil skimmer selection guide. The newly designed guide provides a quick and easy way to match the appropriate skimmer for a wide variety of applications. The grid layout can quickly determine the appropriate size, belt material and oil removal capacity, with quick links that connect to more detailed performance specifications.
Belt skimmers are the most economical method for separating oil and water. However, not all applications are alike, so choosing the right oil skimmer and belt material is essential in order for successful oil removal. Although designs vary, all oil skimmers rely on specific gravity, surface tension and a moving medium to remove floating oil from a fluid’s surface. Oil skimmers are simple, dependable and effective tools for removing oil, grease and other hydrocarbons from water and coolants. Often, an oil skimmer by itself can achieve the desired level of water purity. In more demanding situations, oil skimming is a cost-effective means of removing most of the oil before using more complicated and costly treatments such as coalescers, membrane filters and chemical processes.
To view the oil skimmer selection guide, visit www.abanaki.com/skimsel.
Abanaki Corp.
Chagrin Falls, OH
