News
New Fluke Temperature Calibrators Designed for Pinpoint Tests, High Accuracy
Tammy Shipps | April 21, 2014
04 April 2014
0414flukeprod1Fluke Corp. has introduced two single-function calibrators that, by simulating process temperature sensors, provide accurate temperature calibration. The new Fluke 712B RTD and 714B Thermocouple Temperature Calibrators allow instrument, process, and plant maintenance technicians to test temperature instrumentation quickly. The Fluke 712B measures and simulates 13 different resistance temperature detector (RTD) types and resistance. The 714B measures and simulates 17 different thermocouple types as well as millivolts.
Both verify process sensors by direct comparison of measured versus reported temperatures. The calibrators also measure 4 to 20 mA signals with 0.001 mA resolution while simultaneously sourcing a temperature signal. Both readings are displayed on the backlit display for easy transmitter calibration. They can correlate measured mA to programmed 0 and 100 percent temperature settings to verify the 0 and 100 percent readings in a temperature transmitter.
They also feature linear ramp and 25 percent step auto-ramp based on 0 and 100 percent settings. Value readings are kept in memory to restart testing when the calibrator turned on again. Both calibrators feature built-in magnetic hangers for easy mounting during measurement. More information is available at www.fluke.com/temperature_calibration.
Fluke Corp.
Everett, WA
Tammy Shipps
