Introducing the latest in vibration analysis technology – Emerson’s CSI 2140 Machinery Health™ Analyzer. The CSI 2140 delivers four-channel simultaneous data collection, wireless and Bluetooth communication, and full-color touchscreen navigation. It has the fastest route collection capability on the market, and is ergonomically designed for long hours in the field.
Compact, rugged PC
PACSystems IPC 2010 compact industrial PC is a rugged industrial computer designed to handle a wide range of machine and discrete-part manufacturing automation applications. The unit addresses this by […]
Expanded client services
Digital Lifecycle Solutions (DLS) offerings build upon application services previously delivered to licensees of the PlantESP solution. Aligning with different stages of a manufacturer’s operational journey, the enhanced services […]
Extended-temperature sensors
LVDTs with an extended 400 F temperature range for use where temperature spikes are possible are said to ensure reliable position measurement without failure. Units are available in ranges […]
Power supplies
WAGO Pro2 series performance power supplies now include 12 VDC single-phase power supplies with 120W or 180W outputs, 24 VDC three-phase power supplies with 120W or 240W outputs, and […]
Rotary lobe pumps
The EP series rotary lobe pumps are said to handle extreme conditions and constant high pressures. A heavy-duty gearbox allows a uniform pressure output of 260 psi (18 bar). […]
Methane monitor
ADGiLE is a methane monitoring solution said to provide optical gas imaging (OGI) with comprehensive edge-detection analytics. The system consists of a pan-tilt gas imaging camera, edge computing device, […]
POPULAR CATEGORIES
- Machinery Solutions
- Maintenance & Reliability Solutions
- Energy Efficiency
