Compact-Footprint, Refrigerated Dryers for Rotary Compressors Offer Simplified Maintenance
Jane Alexander | June 9, 2014
Kaeser Compressors has released a new line of refrigerated dryers for use with rotary compressors up to 40 hp. The Kryosec TAH-TCH series can handle flows from 12 – 159 cfm. Incorporating copper-brazed stainless steel plate heat exchangers, they provide drying at ambient temperatures up to 122 F.
The units’ air-to-air and air-to-refrigerant heat exchangers are combined with the condensate separator in a single assembly to save on space and weight. According to the manufacturer these new units have an exceptionally compact footprint and, with their low profile, easily fit under machine platforms and in tight corners. They can also be wall-mounted.
Other features include an Eco-Drain electronic demand drain for dependable condensate drainage without pressure loss and a hot gas bypass valve that adjusts cooling capacity to match varying conditions. With all components, including heat exchangers, refrigerant circuit, condensate separator and drain, easily accessible when the side panels are removed, maintenance is simplified.
