Products
Eaton Launches User-Friendly Modular Gas Analyser for the Biogas Market
Melissa Larson | July 31, 2014
Eaton logoPower management company Eaton has launched the MTL GIR6000 biogas analyser to help ensure reliable, accurate measurement of gases in biogas production. The MTL GIR6000 gas analyser requires minimal maintenance and enables process engineers and biogas plant managers to reduce downtime and improve their processes.
 The analyser can measure up to six gases, including methane, oxygen and hydrogen sulphide, and is designed with dedicated sensor modules and long-life, established sensor technology to provide continuous, accurate and reliable readings. The MTL GIR6000 analyser uses an modular concept that makes it user-serviceable and reduces lifetime service costs through quick and easy maintenance procedures that require no special tools or training.  As a result, service engineer site visits are largely avoided with the guidance of the built-in self-diagnostic routines and pre-configured intelligent sensor modules.
 The gas sensor modules can be individually replaced – simply slide in and lock with an automatic seal integrity check – which helps to ensure minimal downtime, increased process efficiency and reduced operational maintenance cost.
Melissa Larson
