News Uncategorized
Emerson Power Transmission Solutions Launches Torque-Amplification-Analysis Program
Jane Alexander | August 25, 2014
Screen Shot 2014-08-25 at 12.48.00 PM
Emerson Power Transmission Solutions, a business of Emerson Industrial Automation, has announced the launch of a new torque-amplification-analysis program. Focused on precisely measuring the true torque loads and vibration frequencies experienced by rolling mill drives, it’s part of Emerson’s efforts to help mills process tougher alloys, increase output with thicker slabs or higher speeds, protect against cold-end slabsand mitigate torsional vibration.
Developed by Emerson Kop-Flex, the new analysis program combines computer modeling of complex drives with true torque measurements to determine the actual torque-amplification factor (TAF) on the drive rather than inferring it from motor-current readings. Kop-Flex then engineers solutions that reduce TAF and torsional vibration using alterations of coupling stiffness, improved overload protection, resilient couplings and other strategies.
“TAF can be defined as the peak torque divided by the rolling torque,” explained Dan Phillips, Kop-Flex Global Manager, Metals Industry Service. “It’s a unit-less factor that shows the severity of a torque spike. It is affected by system dynamics or how the inertias and stiffnesses are distributed across a complex drivetrain. Entry conditions, such as slab temperature, speed, angular clearances and backlash in gear components all play a role.”
According to Phillips, the old rule of thumb for mill drives was to keep the TAF under 2.5, but with motor sizes and slab thickness increasing and new alloys being processed, the old rules don’t apply. “As rolling torque increases,” he says, “so will peak torque, degrading overload protection devices, bearings, couplings, work rolls, etc. Often the first sign of a torsional problem is equipment failure.”
TAF analysis applies measured torque readings to 3D mode shape analysis to visualize how a drive train twists at various locations to determine where to alter stiffness or increase damping. “We use torque-monitoring hardware developed for high-speed turbomachinery drives, so it is already mill-hardened, accurate and capable of high-rate data sampling,” notes Phillips. “High-rate sampling using strain gages allows the system to capture torque spikes that would normally be unseen on motor-current readings because of the high-inertia in these drives. At lower sampling rates, peak torque measurements are often truncated because the system cannot capture them. High-rate sampling is a must to capture these events in a complex, high-inertia drive.” He points out Kop-Flex has used the technology to engineer TAF reductions as high as 50%.
TAF data capture and analysis can be a temporary service or integrated with a mill’s CSI 6500 condition-monitoring system as an ongoing service. The CSI6500 Machinery Health Monitor from Emerson Process Management is widely used in the steel industry to track bearing vibration, temperature and other data. Additional data on torque loads allows the mill to correlate the measured torque with slab temperature, force on the work rolls, speed, gap, etc., so engineers can better understand the root cause and make needed changes on scheduled downtime, before cumulative damage leads to an unscheduled outage.
Jane Alexander
