Emerson Introduces Rotary Actuators for Internal Valves In LP-Gas Services
Melissa Larson | August 14, 2014
Emerson Process Management has released the Fisher P700 rotary style actuator for use with Fisher C series internal valves in LP-Gas services. These actuators offer a reliable method to remotely operate internal valves on storage tanks, bobtail route trucks, and bulk transports.
The P700 series actuators assure efficient performance of both the actuator and the Fisher C series internal valve to deliver full valve capacity. It is designed to precisely actuate Fisher internal valves and eliminate side-load wear. The P700 series minimizes actuator air consumption, while maximizing service life. The rotary actuators provide easy installation, durable construction, and reliable performance.
The actuators are compatible with air, nitrogen, or propane vapor. They include a ¼” UL-approved thermal fuse plug to provide shutoff in the event of an emergency situation, and feature a maximum allowable inlet pressure of 125 PSIG.
