Products
Fuel Purifier Removes 99.997% of Visible Water
Melissa Larson | August 4, 2014
5x32 PR 140804Dieselcraft Fluid Engineering has developed a new Model 5×32 Fuel Purifier that removes 99.997% of the visible water at flow rates up to 12 gallon per minute and over 95% of the large contaminates found in diesel fuel. This is all done without the use of replaceable, changeable or cleanable filter elements. There are no moving parts, except the fuel inside the purifier. There are no elements to clean and dispose of, only purging the water and particulates. This new model is ideal for those that need to incorporate a fuel polishing systems on a fuel storage tank. The Dieselcraft Purifier can be mounted on the engine, at the fuel dispensing pump, where it cleans the fuel before it goes into a vehicle or in a fuel polishing and re-circulating application to maintain stored fuel.
Melissa Larson
