ITT Launches Hygienic Diaphragm Valve Platform
Melissa Larson | August 18, 2014
ITT Corp’s Engineered Valves brand has launched a new line of hygienic diaphragm valves designed to reduce maintenance time and total cost of ownership for today’s BioPharm manufacturing facilities. As the latest platform to be added to the Engineered Valves product family, the EnviZion valve helps customers install, operate and maintain their systems more efficiently and reliably.
EnviZion’s embedded technologies allow for a more streamlined installation and maintenance process, delivering less downtime, longer preventative maintenance cycles and greater production capacity for manufacturers.
Assembled with a simple mount and turn motion, the EnviZion valve is installed in approximately three minutes without using any special tools or difficult torqueing procedures. The valve’s 360 deg. active seal protection provides leak-free operation, helping eliminate the risk of contamination and the need to re-torque after thermal cycling.
