FLIR Systems Announces AX8 Temperature Sensor for Industrial Automation
Melissa Larson | September 24, 2014
FLIR Systems, Inc. announced today the launch of its new AX8 fixed-mount temperature sensor. Combining thermal and visible cameras along with FLIR’s proprietary MSX technology in a small, affordable package, the AX8 is easy to install in space-constrained areas for automated and uninterrupted condition monitoring of critical electrical and mechanical equipment.
Enabled by FLIR’s ground-breaking Lepton® thermal imaging core, the AX8 provides early detection of temperature-related issues in electrical and mechanical equipment, guarding against unplanned outages, service interruptions, and equipment failure. The AX8 is the ideal temperature sensor for continuous condition monitoring and fire prevention without the need for periodic manual scans.
The AX8 thermal imager has 4,800 active temperature points per image, provides streaming temperature data over industry-standard interfaces (Ethernet/IP and Modbus TCP) for easy analysis, has a built-in web interface, and includes a full suite of Analysis and Alarm functions that automatically send alerts when the AX8 detects elevated temperatures.
Measuring only 54 x 25 x 95 mm, the AX8 integrates easily into electrical installations or any manufacturing environment. The AX8’s streaming thermal, visual, and MSX video is output in standard MJPEG, MPEG, H.264 formats, adding multipurpose image capabilities.
With all of these features in a compact form factor, the FLIR AX8 addresses the condition monitoring and safety needs for many environments, including:
• Process and manufacturing industries
• Data centers
• Energy generation and distribution
• Transportation and mass transit
• Storage facilities
• Refrigeration warehouses
• Engine rooms.
