Products
Rosedale Offers 7180 Series Hydraulic Lube-Oil Filters for Reclamation and Maintenance Operations
Melissa Larson | September 9, 2014
The 7180 series hydraulic lube filters from Rosedale Products Europe are designed for oil reclamation and maintenance operations. Housings incorporate an eyenut cover that is easily removed, reducing time spent on cartridge change-out. The side-in/side-out piping arrangement is available in 1”, 1-1/2”, and 2” NPT connection sizes. Housings are electropolished creating a smooth, easy-to-clean surface.
Products in the 7180 series accept single 718 or 736 style filter cartridges, and are rated at 1μ absolute to 100μ nominal. They seal on the housing’s elevated pedestal and are retained by a threaded post and cap assembly. Applications include: bulk oil handling, coolants, cutting oils, fuels, hydraulic oils, lubrication oils, process liquids, quench oils, rolling mill oils and solvents.
Melissa Larson
