Martin Engineering Secondary Conveyor Belt Cleaner Designed for Easy Maintenance
Melissa Larson | September 30, 2014
Martin Engineering has announced a secondary conveyor belt cleaner engineered to improve performance and reduce maintenance time, even as average belt speeds and loads continue to increase. The Martin SQC2STM Cleaner features individually cushioned tungsten carbide blades for effective cleaning without risk to the belt or splices.
The new design forms a single sealing edge that maintains steady, adjustable pressure. Patented rubber buffers maintain the cleaning pressure throughout the blade’s life, while deflecting sufficiently to allow splices to pass without harm and ensuring compatibility with reversing belts or those that experience backup at shutdown. Moving parts are zinc plated to resist seizing or rusting.
“The blades conform to the belt profile, adjusting individually to deliver continuous contact across the belt,” explained Dave Mueller, Senior Product Specialist at Martin Engineering. “In a perfect world, bulk materials would load uniformly, wearing the blade evenly, but that rarely happens. By having multiple segments attached to a single rigid assembly, the tension can be maintained and adjusted accurately, quickly and safely.”
