Products
Reality Concepts Debuts Belt Alignment Tool System
Melissa Larson | September 22, 2014
The B.A.T. Belt Alignment Tool system is the latest innovation in laser belt alignment systems, utilizing patented GlowLine green laser technology, and it is available in multiple configurations for every application. With TruView B.A.T. Belt Alignment Tool systems and targets, the offset and angularity of the entire sheave face can be easily seen, and precision adjustments made. Green laser configuration enables users to check the offset, twist and angularity between both sheaves at the same time. The B.A.T. Belt Alignment Tool is fast, intuitive, accurate and easy to use. It is designed for precision alignment of: V-belts, timing belts, flat belts and chain drives.
Melissa Larson
