Siemens Introduces Profinet Driver to Develop PC-based Automation
Melissa Larson | September 15, 2014
Siemens Industrynow offers a Profinet Driver for controller applications, expanding its expertise in developing PC-based automation solutions for series machine manufacturing.
The driver is delivered as a source code, simplifying individual Profinet communications on a standard PC. No additional hardware is needed for connections, only a standard PC Ethernet interface.
The Profinet driver is suitable for standard operating systems and is configured with an open XML interface. Engineering tools, including the TIA Portal or Step 7, may be used to further simplify configuration.
The new driver supports Profinet with real time (RT) and achieves cycle times of as little as 1 ms when using a real-time operating system.
