Technology Showcase: Vibration Monitoring
Greg Pietras | September 8, 2014
Delta Technologies ClearView Sensors
According to Delta Technologies, its patent-pending ClearView Sensor products deliver a range of benefits in industrial- and transportation-equipment applications. The entire ClearView family of products is embeddedable in a range of materials, including ceramic, rubber, metal and plastic.
Delta Technologies
delta-techs.com
SPM Lenova Phase II Upgrade
According to SPM Instrument, its Leonova Diamond and Emerald products have been designed to provide outstanding performance and usability for all industrial environments. The company says the recent Leonova Phase II upgrade, the first major upgrading of this lineup, offers, among other things, a significant performance increase and a strong set of vibration-analysis functions, including some especially suited for gearbox analyses. Parallel execution of multiple measuring assignments leads to faster data acquisition and processing and makes large-scale measuring routes more efficient.
SPM Instrument, Inc.
spminstrument.com
Emerson CSI 9360 Vibration/Position Transmitter
Emerson Process Management’s CSI 9360 vibration/position transmitter is designed to protect compressor, pump and fan assets. Developed using OEM-supplied specifications, it detects emerging sleeve-bearing issues by capturing vibration or position data and translating it into a 4-20mA signal for monitoring and advanced warning of problems before significant equipment damage occurs or production is impacted.
emersonprocess.com
Meggitt Redesigned VibraLink (VL) Enclosures
Meggitt says its redesigned, corrosion-resistant, NEMA 4X (IP66)-rated VibraLink (VL) enclosures facilitate quick and safe data acquisition in the harshest industrial environments. By housing permanently mounted sensors (with up to 48 cable runs) that detect changes in the vibration signatures of rotating equipment, they provide a central data-collection point that eliminates walk-around routes.
Meggitt Sensing Systems
meggitt.com
Balmac VPM Meter
Balmac’s VPM Meter is a portable, handheld instrument that measures vibrations per minute (VPMs). Applications include concrete-consolidation equipment like internal and external vibrators, shaker tables and vibrating screens, and vibrating bulk-solids-processing equipment like bins, hoppers and conveyors. The company says this meter is not only easier to use, it’s more accurate (within 10 VPMs) than any vibrating reed tachometer. All Balmac products are made and serviced in the USA.
Balmac, Inc.
balmacinc.com
