Products
Emerson Introduces System Plast NG Evo Chain for High-Speed Beverage Conveying
Melissa Larson | October 23, 2014
Emerson’s Power Transmission Solutions business will introduce its new System Plast NG™ Evo conveyor chain at Brau Beviale, and will also exhibit a wide variety of bearings engineered for beverage industry applications.
The new NG Evo chain is made from a proprietary, low-friction material for dry high-speed conveying. “NG Evo builds on the success of original NG chain, which is already widely used in the bottling industry,” said Jeff Himes, System Plast Senior Product Manager. “The new chain provides a higher breaking load, greater elasticity, lower coefficient of friction and much greater abrasion resistance than the original. All of the physical properties of the original NG chain have been enhanced.
NG Evo significantly expands options for dry conveying to meet sustainability and water conservation goals, which will grow in importance for beverage processors worldwide. Beverage handling conveyors are typically lubricated with soap and water that uses two to three times more water than goes into the finished product. There are obvious costs for this, but the hidden cost for wet conveyor is in the slip hazard, pumps, leaks and premature failure of bearings, sensors and other conveyor components. NG Evo chain also reduces the costs and energy for water reclamation and treatment, and eliminates the wear paste buildup caused by mineral-oil-based dry lubricants.”
The companion Nolu®-S wear strips and guides enable reduced-lubrication or lubrication-free, high speed conveyor operation. They are made of a unique resin with a solid lubricant that dramatically reduces the coefficient of friction. Nolu-S helps reduce noise, energy consumption, squeaking, and chain pull/belt fatigue. The combination of NG Evo chain and Nolu-S wear strips can reduce a conveyor’s energy requirements by up to 30 percent, with service life as much as five times greater.
Melissa Larson
