Alicat Releases Gas Select 5.0 Firmware for its Mass Flow Meters and Controllers
Melissa Larson | November 6, 2014
Alicat Scientific has expanded its Gas Select firmware to include a library of up to 130 preloaded gases, referenced to NIST Prop 9, and an industry-first utility for defining mixed gas compositions. New to Gas Select 5.0, the COMPOSER utility gives users the ability to quickly program and store up to 20 personalized gas compositions directly on Alicat mass flow meters and mass flow controllers. With COMPOSER’s capabilities, Alicat devices adapt to a range of applications and users’ changing needs.
The Gas Select firmware comes standard on all Alicat mass flow meters and controllers. Version 5.0’s expanded library now includes up to 130 preloaded full gas calibrations, depending on the Alicat instrument series. In addition to many pure gases, Gas Select 5.0 includes numerous gas mixes commonly used in bioreactor, welding, manufacturing, power, refrigerant and medical industries. The library has also been updated to include complete NIST Ref Prop 9 gas properties data for the preloaded gases and gas mixes.
A brand new feature of the Gas Select upgrade is the addition of the COMPOSER module, which brings a new level of customization and flexibility to accurate mixed gas measurement. Using the device’s integrated digital display, users can define gas compositions to 0.01% for each of up to five constituent gases. Up to 20 gas mixes can be created and stored simultaneously on each device. Users who operate Alicat instruments via computer can generate gas lists for multiple devices in seconds with single line RS-232 commands. As personalized gas compositions can be added or deleted quickly, Alicat instruments easily adapt to different flow needs in the future.
