Products
FLIR Debuts AX8 Temperature Sensor
Melissa Larson | November 18, 2014
The AX8, ideal for continuous condition monitoring and fire prevention, is a small and extremely affordable temperature sensor that provides early detection of temperature-related issues in electrical and mechanical equipment, guarding against unplanned outages, service interruptions, and equipment failure.
Key features include:
• Compact size: Measuring only 54 x 25 x 95 mm, its compact size allows the AX8 to integrate easily into electrical installations or any manufacturing environment
• Extremely affordable: $995 USD
• Thermal sensor: 4,800 active temperature points per image
• Automatic alarms: Relative set of built-in analysis and alarm functions give immediate warnings when temperature thresholds are exceeded
• Compact and easy installation: Two cable connection. Industry standard interfaces: EthernetIP and Modbus TCP. Built-in web interface for easy alarm set-up.
Melissa Larson
