Products
HARTING Introduces High Temp Connector Series for Environments Up To 200°C
Melissa Larson | November 14, 2014
HARTING’s new Han High Temp connectors are designed to circumvent the limitations of deploying connectors in hot manufacturing applications up to 200ºC like mold machines and casting equipment. Conventional connector solutions involve locating the connectors well away from high temp areas of the machinery, requiring additional cabling. The Han High Temp can be located right at the machine, saving on cabling and potentially simplifying machine design and wiring. The connector can be mated and unmated at temperatures up to 200ºC due to a special non-adhesive seal HARTING implemented in the connector.
The Han High Temp is based on the well-established Han B and Han E series, using the same panel cutout dimensions. The aluminum die cast hoods and housings feature a highly compressed surface with excellent non-stick properties allowing the connector to be unmated without the gasket sticking. The Han High Temp series features very rugged inserts made of injection-molded, liquid crystal polymer plastic (LCP) that deliver outstanding temperature resistance coupled with excellent mechanical stability. New temperature-resistant contacts (crimp or screw termination) ensure reliable connections with minimal contact resistance even at extreme temperatures.
Melissa Larson
