Miller Multiprocess Welder Offers Big Capabilities in a Smaller Package
Melissa Larson | December 4, 2014
Designed specifically to withstand harsh environments, the new Dimension 650 multiprocess welder from Miller Electric Mfg. Co. offers an unbeatable combination of durability, output, efficiency and capability — all in a smaller, easier-to-handle package. The Dimension 650 provides both power-intensive output for heavy welding and carbon-arc gouging, as well precision arc characteristics designed for thin-metal welding.
This compact and energy efficient machine features a tough, corrosion-resistant, all-aluminum case to protect against the environment. Exclusive protection input inductor protects against “dirty power” commonly found on jobs, preventing power fluctuations from affecting performance or reliability.
Adding to its durability, Miller-exclusive Wind Tunnel Technology directs internal airflow to protect sensitive electronic components from dirt, dust and debris, significantly improving reliability. Fan-on-Demand operates only when needed, reducing noise, power consumption and the amount of airborne contaminants that are pulled through the machine. 3-1/4 inches of ground clearance keeps the machine away from water, mud and dirt to protect interior components.
The reduced size and weight of the new Dimension 650 makes it easier to handle while still providing the welding performance of a larger machine. Compared to the legacy Dimension 652, the new Dimension 650 is 3-1/2 times lighter and has a 40 percent smaller footprint, making it easier to move.
The Dimension 650 features high electrical efficiency that allows for more welding using 32 percent less power. Its full-load welding draws fewer than 50 amps of power, so the machine can function properly in a wider variety of locations.
