Products
Atlas Copco Showcases Tier 4 Final QAS 25 Generator at POWER-GEN International
Melissa Larson | January 23, 2015
One of Atlas Copco’s latest additions to its generator lineup, the compact QAS 25, is equipped with an Isuzu 4LE engine and a Diesel Oxidation Catalyst (DOC) to achieve Tier 4 Final emission levels. The generator is ideal for heavy-duty use in several industries, including rental, oil and gas and construction. It is also an exceptional option for powering events. It can be used for prime or standby power and is designed to withstand the rigor of demanding use in the field.
Atlas Copco exhibited the QAS 25 at Booth 1800 during the 2014 POWER-GEN International tradeshow December 8-11 in Orlando, Florida.
The QAS 25’s overall durability as well as the quality and dependability of its interior components give it one of the highest resale values in the industry. For example, the QAS 25 is mounted on a durable frame and surrounded by a robust enclosure formed from galvanneal steel and powder coated for a long-lasting, scratch- and corrosion-resistant surface.
In terms of performance, the generator is equipped with a dependable Leroy-SomerTM AREP alternator for optimal motor-starting capability. Deep Sea 4510 controls are comfortable, reliable and easy to use. The unit comes standard with two-wire remote start capability and features a 72-gallon fuel tank for a 45-hour run time, nearly twice the run time of some competitive models.
The unit’s versatility can be seen but not heard. The QAS 25 enclosure is sound attenuated and has a vertical radiator and exhaust discharge to ensure low dBA levels for use on noise-sensitive jobsites, residential areas or at events. Its voltage selector switch allows operators to adjust the machine’s output to 480 and 208/240 volt 3-phase settings as well as 120/240 volt single phase for varying applications and equipment. For additional safety, the locking front panel voltage adjust potentiometer prevents unintentional adjustments to the voltage, which can cause overheating or equipment damage. This versatility gives users greater flexibility on the jobsite and can increase utilization at rental centers. The 120vac GFCI duplex receptacles are always powered, giving users the ability to operate small hand tools while running larger loads, such as vendor stands or jobsite trailers.
Melissa Larson
