Products
Omega Introduces High Accuracy Industrial Pressure Transducer
Melissa Larson | January 20, 2015
The Omega PX509HL Series industrial differential pressure transducers are shock and vibration rated with high accuracy and are specifically designed to provide long life in demanding industrial areas (ruggedized Containment Pressures up to 10,000 psi). The compensated overload range minimizes errors induced by large line pressures. Features include welded stainless steel construction, user accessible potentiometers for zero and span, and demountable electrical terminations or a fixed conduit fitting without trim pots.
They are temperature compensated over a broad range providing excellent thermal properties and high long term stability. A precision micro-machined silicon sensor is at the core and provides a very stable reading with exceptional high accuracy of 0.08% and a broad compensated range of -20 to 85°C on most ranges.
Modular construction allows for fast delivery of most configurations, customized models also can be developed quickly to suit your exact needs.
Melissa Larson
