Products
Enerpac Torque Wrenches Provide Durable Solution for Narrow Access Bolting
Melissa Larson | February 26, 2015
Enerpac introduces its UltraSlim torque wrenches, designed to provide a robust, high-performance bolting solution in tight spaces that may not accommodate standard tools. Featuring a lean, stepped width design, UltraSlim torque wrenches can easily be mounted over bolts in narrow access applications. In addition to a compact size, UltraSlim wrenches provide superior accuracy with plus or minus three percent across the full stroke.
With a user-friendly design, Enerpac’s UltraSlim torque wrenches are simple to use and maintain. Few moving parts allow for quick maintenance in the field, while a fast release drive unit enables easy exchange of cassettes with no tools required. UltraSlim torque wrenches combine premium grade components with an enhanced tool geometry to provide bolting professionals with one of the toughest, and most durable narrow access solutions on the market.
For increased versatility, the bi-hexagonal UltraSlim cassette design allows twice as many positioning points on a nut or bolt. A new top-mounted straight handle facilitates safe and easy access to hard-to-reach fasteners. To accommodate diverse applications, an optional angled handle is also available on request.
All UltraSlim torque wrenches are CE-ATEX declared for use in explosive environments, and are shipped complete with a unique calibration certificate, helping to ensure accuracy and traceability.
Melissa Larson
