Products
GTI Debuts Ultrasonic Sensor for iPad
Melissa Larson | February 16, 2015
GTI Predictive Technology is proud to announce another tool to expand your iPad’s capabilities. This ultrasonic sensor can be used to test bearing lubrication and spot air leaks. The range and pin-point accuracy of this sensor make capturing readings a simple process.
The app can record, analyze and use slow down playback for sounds normally impossible to hear. The app can also analyze any imported audio file into a spectrogram context. The sensor is plug and play; connected through a single USB cable into the iPad.
Melissa Larson
