Products
Siemens Presents High-Efficiency Helical Bevel Gear Motors
Melissa Larson | February 2, 2015
Siemens’ SIMOGEAR 2-stage helical bevel unit gives users higher ratios in the first gear stage than traditional designs. All told, the unit averages 2% higher efficiency than 3-stage units. For any continuous duty application, that translates to substantial energy savings over the long term. Features include:
• Mounting options: Foot, flange, and torque arm
• Inch or metric shafts in common dimensions
• Shaft types: Solid, hollow, and SIMOLOC
• Gear teeth hardened and ground for infinite life
• Synthetic oil standard for longer maintenance intervals
• Aluminum housings are lightweight and do not require paint
• Inverter-duty NEMA Premium® and NEMA Energy Efficient motors (230/460VAC, 60Hz)
• Conduit box with NPT-tapped holes
• Standard 9-pin terminal block in 3×3 configuration
Melissa Larson
