Products
SPECTRO Analytical Instruments Debuts Hi-Res Spectrometer
Melissa Larson | February 17, 2015
SPECTRO Analytical Instruments has announced its new SPECTRO ARCOS high-resolution ICP-OES spectrometer, the first and only spectrometer featuring the fast and convenient selection of axial plasma or radial plasma observation in a single instrument — without any optical compromise.
Designed for use in the most demanding elemental analysis applications in industry, science, and academia, the new SPECTRO ARCOS easily surpasses the performance limitations of conventional ICP-OES instruments — dramatically improving sensitivity, stability, and precision, while lowering operating costs with the introduction of innovative components, unique capabilities, and optimum flexibility.
The new SPECTRO ARCOS establishes a new ICP-OES performance class for complex analytical tasks — resolving a wide array of inherent problems in traditional spectrometer design — and caps 30 years of SPECTO experience in developing advanced solutions for the elemental analysis of metals, chemicals, petrochemicals and other materials.
Features of the new SPECTRO ARCOS include:
Axial or Radial Plasma Observation: SPECTRO’s unique new MultiView capability delivers unmatched performance improvements in accuracy and stability and allows for the fast and convenient selection of axial plasma or radial plasma observation with no optical compromise.
ORCA Optical System: The CCD optic system with a Paschen-Runge mount assembly delivers a matchless resolution of 8.5 picometer in the wavelength range from 130 to 340 nm.
Innovative Power Generator: A unique new solid-state generator design that provides the highest plasma power available for extreme or quickly changing plasma loads.
Elimination of the Need for Purge Gases: SPECTRO’s UV-PLUS sealed optical chamber ends the need for the purging of argon or nitrogen gases — along with the related supplies, maintenance costs, and downtime.
No External Cooling System: Air-cooled interface technology and the completely air-cooled generator eliminates the need for an external cooling system — along with the associated, and often substantial, equipment, power, and maintenance costs.
Editor’s note: The elemental analysis of oils is important for many petroleum laboratories and refining processes. Samples can be crude oils, new and used lubricating oils, gas or fuel oils, and the elements to be analyzed vary with the product. For wear metals in lubricating oils, aluminum, copper, nickel or iron can be indicative of wear in oil-wetted components. Other elements like silicon, magnesium or potassium can be indicative of contamination of the oil. And also, the correct addition of elements, such as molybdenum, calcium, barium, phosphorus, and zinc must be monitored.
Melissa Larson
