Larson Electronics Debuts Compact Quadpod with a 320 Watt LED Work Light
Melissa Larson | March 31, 2015
Larson Electronics has added to its extensive range of industrial grade lighting equipment with the release of a 320 watt quadpod mounted work light. Built to provide a high power lighting solution that requires minimal setup time, the WAL-LQP-320WSA-LED provides operators with an ideal lighting solution that features a quadpod with solid wheels for portability and a single 320 watt LED light head.
The WAL-LQP-320WSA-LED from Larson Electronics is a quadpod mounted work area light that provides 29,446 lumens of light output. Thirty-two CREE XM-L2 ten watt LEDs producing 920 lumens each are arranged in rows and paired with high purity optics to produce a 40° or 60° beam spread to provide more light over a larger area nearer the fixture making it ideal for use as a dedicated work area light. The light fixture is IP67 rated waterproof and offers increased durability, longer lamp life, and low power consumption.
This portable light tower has a removable light head assembly mounted on top of a four legged aluminum quadpod equipped with wheels for easy positioning from one work space to another. This adjustable and collapsible quadpod can be extended to 9 ft. and collapsed to 5 ½ in. The light assembly on this unit can be removed by releasing the hand knob and sliding the light and mounting bracket off of the center support while the legs can be collapsed, aiding in deployment, storage and transportation.
The WAL-LQP-320WSA-LED is a heavy duty unit designed for use in inclement conditions and for overall longevity in difficult construction environments with heavy duty aluminum construction and stainless steel hardware for maximum durability.
