Products
Rotork Soldo Range Switch Boxes are Weatherproof and Intrinsically Safe
Melissa Larson | March 26, 2015
The Soldo SP series limit switch boxes from Rotork provide a compact design and the most economical solution for both visual and remote electrical indication of rotary valve/actuator position. Integral NAMUR mounting legs provide additional cost saving by eliminating the need for a separate mounting bracket. The SP series is suitable for use in IP65 weather proof applications. Optionally it can be Exia certified by use of inductive NAMUR sensors and other dry contact switches.
Melissa Larson
