Safety Products Showcase
EP Editorial Staff | March 10, 2015
Hard Hat With Back-of-Head Protection
Honeywell’s North Force hard hat offers 24% more back-of-head coverage than standard Type I hard hats, according to the company. The patented shell design of the new design provides increased rear-head coverage without restricting range of motion, while an innovative rear-impact attenuator absorbs force to minimize injuries. The hard hat is suited for upstream oil workers, miners or workers in other industries in which slippery or icy conditions exist. It is constructed of a unique, lightweight shell material that offers high-impact resistance and stands up to extreme temperature changes ranging from -30F to 120F. A six-point suspension system with five adjustment areas allows for a customized, comfortable fit.
Honeywell Safety Products
Smithfield, RI
honeywellsafety.com
APM Software with Process Safety Capabilities
AssetWise APM V7.3 from Bentley Systems, Inc.., is an all-in-one analysis and information-management software platform for asset reliability that now advances process safety. The software is designed to meet the requirements of reliability, integrity, safety, and maintenance managers and engineers in industries ranging from oil and gas, petrochemical, and mining and metals to power generation and other utilities. It ensures that assets are safe and reliable and that they are inspected and maintained to reduce or eliminate risk. Users further benefit from the elimination of unexpected downtime, increased asset availability and utilization, reduced maintenance costs, and support for regulations and safety standards. The software’s new process safety features help users manage the integrity of safety systems and hazardous processes, thereby preventing failures and catastrophic incidents.
Exton, PA
bentley.com
Glow-in-the-Dark Floor Safety Tape
Glow Floor-Mark from Visual Workplace, Inc., is a peel-and-stick, glow-in-the-dark safety product that helps building and vehicle personnel find their way in darkness, whether it’s nighttime, during a power failure, a building fire filled with smoke, a natural disaster or other emergency. It glows brightest for the first 60 minutes, then fades to remain lightly visible for several hours in total darkness. The product is light green when lights are on, and emits a green/yellow glow when lights are off. Its thin, durable profile is designed for industrial environments, and specifically for use near exits, passageways and staircases. OSHA-compliant, the tape is easy to remove, and is available in 1-in. and 2-in.-wide X 30-ft.-long rolls.
Byron Center, MI
visualworkplace.com
Lockout Tagout Stations
RecycLockout Lockout Tagout Stations from Zing Green Safety Products support compliance with 29 CFR 1910.147, and provide the lockout devices needed to control hazardous energy when servicing machinery. Stocked with safety padlocks, hasps and lockout tags, they provide a comprehensive lockout tagout program that ensures worker protection and OSHA compliance. The highly visible stations can be mounted near servicing areas, and keep necessary lockout devices available to authorized personnel during critical maintenance/repair operations. They have the added benefit of being manufactured with UL-validated high-content recycled materials that support sustainability initiatives and LEED credits.
ZING Green Safety Products
Oswego, IL
zinggreenproducts.com
Reflective OSHA Safety Signs
Using reflective-sheeting, highway-sign technology, safety signs from Lyle Signs can be seen during the day, night or in dark or dimly lit conditions. The signs will not crack, peel or fade, and can be applied indoors or outdoors. The reflective technology used on the signs is designed to make them brighter and more easily seen from greater distances, alerting employees to potentially life-saving information.
Lyle Signs, Inc.
Minneapolis, MN
lylesigns.com
Personnel Mustering Application
Apprion’s ION Mustering Application provides real-time information about the status of employees and contractors to locate personnel immediately and communicate with them to ensure safety. The app uses WiFi, GPS or RFID tags to provide continuous, accurate situational awareness and visual confirmation of personnel safety. It also includes mustering-area entry logs for rapid confirmation, and procedural documents and event logs for future safety audits.
Apprion
Mountain View, CA
apprion.com
Lightweight, Versatile Respirator
The Versaflo Powered Air-Purifying Respirator TR-600 from 3M is designed to endure heavy use and long wear. The lightweight unit is engineered to increase comfort, and its ergonomic design fits close to the body, allowing for greater movement in tight work spaces. It offers multiple airflow rate options for user comfort, and belts designed to be wide and contoured with flexible air channels to minimize heat buildup. The TR-600 has two lithium-ion battery options that allow for up to eight hours of use. Audible, visual and vibratory alarms reflect filter and battery status.
3M
Saint Paul, MN
3M.com
Enhanced Safety Instrumentation System
An enhanced version of the ProSafe-RS safety instrumented system (SIS) from Yokogawa (ProSafe-RS R3.02.20) offers improved connectivity with the ProSafe-SLS SIS, enabling the status of both systems to be monitored onscreen by operators of the CENTUM VP integrated production-control system. The new version also offers enhanced support of widely used open communication protocols, improving connectivity with other companies’ SCADA software. The company’s two SISs—the programmable ProSafe-RS and the solid-state ProSafe-SLS—allow users to select the system that best meets their facilities’ requirements. For customers who use both, the new solution allows the status of both systems to be monitored in an integrated manner.
Yokogawa Electric Corp.
Sugar Land, TX
yokogawa.com
Gas-Detection Data Platform
The GasGard 100 Control System from MSA is a scalable, high-performance data-acquisition and -logging platform for data acquisition and control for fixed flame and gas detection. Open Ethernet connectivity with Web-based configuration and data-monitoring functions allow GasGard 100 Controllers to provide monitoring and historical logging functions. View real time trends via Web browser from any PC without special software. The Gasgard 100 Control System provides fully integrated measurement, display and recording platforms, that when equipped with the company’s line of transmitters and sensors, forms a complete gas-detection solution.
MSA Safety
Cranberry Township, PA
msasafety.com
Online Source for Safety Information
Grainger’s online Safety Resource Center includes safety news as well as information about trends in safety and regulatory issues. It also offers access to the distributor’s Field Safety Specialists team of experts who can help customers solve safety challenges, offer cost-saving proposals and recommend program-standardization strategies.
W.W. Grainger, Inc.
Lake Forest, IL
grainger.com
