Products
LA-MAN Offers .01 Micron Filter
Melissa Larson | April 29, 2015
The patented series of SuperStar .01 micron filters from LA-MAN Corp. are designed to be installed at the point of use to efficiently remove moisture and contaminants from air lines in order to improve and extend the lifecycle of tools and equipment.
The four-stage filter operates most effectively within 25 ft. of the point of use. By incorporating a charcoal absorption element, the filter offers a standard .01 micron rating with flow ranges of 50, 75 or 100 scfm and pressure ratings of 250 psi. The filter is suitable for an extensive array of applications that require the highest standards of compressed air.
Additional standard features include built-in differential pressure gauges and an automatic float drain. The differential pressure gauges provide a visual indication of required maintenance, which is easily accomplished with the installation of the appropriate service kit and without removing the unit from the air system.
Melissa Larson
