Products
Emerson’s Butterfly Valve Combines Cost Savings with High Performance
Melissa Larson | May 7, 2015
Emerson Process Management introduces the Fisher 8590 high-performance butterfly valve that brings a selection of disk seals, actuator designs and material combinations to meeting plant-wide throttling and on-off requirements.
Utilizing a lugged body design across the CL600 size range of NPS3 – NPS24, the 8590 can incorporate a splined shaft that accepts either a spring-and-diaphragm or pneumatic piston actuator.  It is also available with either a square or keyed shaft that combines with hand levers, hand wheels or pneumatic piston actuators.
The pressure-assisted design of the 8590 disk seals provides tight shutoff and permits the use of smaller, less expensive actuators in meeting full ASME B16.34 shutoff capabilities. The unit offers true bidirectional shutoff, which means that torque necessary to open and close the valve remains constant regardless of the differential pressure across the disk.  Slam-shut conditions are not created as the disk nears its seat, which extends seal life and avoids actuator and piping damage.
Melissa Larson
