Products
GP:50 Introduces USB Digital Output Pressure Transducers
Melissa Larson | May 28, 2015
GP:50 NY LTD has announced the GP:50 Model 611/612 Series family of USB-powered digital pressure transducers with automatic temperature and pressure output recognition. The series offers an intuitive and user-friendly interface with direct compatibility to high-speed USB 1.0 and 2.0 formats, along with 18-bit resolution and a 4.8 KHz internal measurement rate. Measured pressure values in absolute, gauge, sealed gauge or vacuum formats may be logged real-time onto any PC or mobile device without costly I/O interface board requirements.
Typical applications for Model 611/612 USB digital output pressure transducers include oil & gas pipeline and valve pressure testing; portable test stands; in-laboratory research; hydrostatic test stands; and calibration stands.
The series is available in pressure ranges up to 100K PSI (1,379 BAR), with standard accuracies of ±0.25% FSO and optional improved accuracies of ±0.05% FSO, as well as improved thermal specifications of ±0.25% FSO/100 °F. Their all stainless steel wetted parts and housings allow for years of reliable operation within demanding environments. Available field options include a 1 to 500 Hz adjustable response time, adjustable baud rate, adjustable station numbers, and digital shunt calibration. They are both multi-drop and field configurable, with optional field re-zero functionality.
Melissa Larson
