Products
OptiSIS Solution is Pre-Engineered Safety Instrumented System for Applications Up to 100 I/O Points
Melissa Larson | May 4, 2015
Rockwell Automation has introduced its new OptiSIS solution, giving industrial operators a pre-engineered safety instrumented system that can help ease deployment and reduce lead times for small and midsized process applications.
The OptiSIS solution is ideal for oil and gas, chemical and petrochemical producers with aging process-safety systems that are either noncompliant or can no longer be maintained. The OptiSIS solution is designed for safety instrumented system applications of 50 or 100 I/O points, including emergency shutdown (ESD) systems, burner-management systems (BMS) and high-integrity pressure protection systems (HIPPS). The version for applications of up to 100 I/O points will be available in the fourth quarter of 2015.
The pre-engineered OptiSIS solution is delivered ready to install, wire and configure, shortening the overall engineering time and eliminating the need for any programming. Users need only enter their logic scenarios into the system’s cause-and-effect graphical interface. The configurations are tested and can then be stored for verification against original safety function requirements – or used at a later date to restore the system to a known state.
Melissa Larson
