SKF Offers Entry-Level Laser Shaft Alignment System
Melissa Larson | May 18, 2015
SKF has introduced the TKSA 31 shaft alignment tool for easy laser alignment at an entry-level price. Developed for rotating machines in industrial applications, the instrument helps customers identify and correct shaft misalignments to improve equipment uptime, reliability and lower maintenance costs.
The TKSA 31 and previously announced TKSA 41 are sharing the same design but TKSA 31 has a lower price than its big brother TKSA 41. In return, the smaller version has lower measurement flexibility and is lacking the camera function that allows pictures to be added to TKSA 41 alignment reports. Both tools are designed to make shaft alignment easy and intuitive, even for operators with minimal experience.
Comprised of two measuring units with large detectors and bright lasers, the TKSA 31 reduces the need for pre-alignment and provides precise measurements, even in challenging conditions. The embedded soft-foot tool helps establish the basis for successful alignment.
The TKSA 31’s liquid crystal display (LCD) with touchscreen navigation makes alignment fast and simple, and measurements can be performed by using the well-known 9-12-3-o’clock positions with additional flexibility of 40 degrees around each. The tool’s live view supports intuitive measurements and facilitates horizontal and vertical machine position corrections.
