Allied Power Products’ Offers HS Series Radial Piston Motor Pneumatic Hoists
Melissa Larson | June 15, 2015
Allied Power Products, Inc. (APPI) has announced the addition of a new model line of pneumatic, radial piston powered hoists to their Columbia product line. The initial introduction of these “HS” hoists includes models with line pull ratings of 3500, 8800 and 16,500 lbs. with hoisting speeds in excess of 100 feet per minute. These units feature heavy duty cast construction and precision planetary reductions with all moving parts internally sealed to ensure full lubrication while minimizing service requirements.
Rated to lift loads vertically, the HS Series of hoists utilize an automatic spring-set, pneumatically-released brake. When used in conjunction with an optional counter-balance valve, operators can move loads quickly and smoothly with precise control. Their robust construction, coupled with the high starting torque and input horsepower of the radial piston motors, makes these hoists well suited for offshore, mining, construction and other challenging work sites.
