BinMaster Offers Submersible Pressure Sensor
Melissa Larson | June 11, 2015
BinMaster’s new PT-500 submersible pressure transducer is an affordable and versatile level sensor that calculates level based upon the amount of pressure being exerted on the sensor from the liquid above it. It can be used in a wide range of liquids including water, wastewater and a variety of chemicals. It is Class 1, Division 1 certified and intrinsically safe for use in hazardous environments. As it has a low current draw, the PT-500 can be used in remote locations and for battery powered applications.
Made of 316L stainless steel, the PT-500 submersible pressure transducer is compatible with many liquids and chemicals. BinMaster offers a variety of rugged housings and cables to ensure the sensor will operate reliably and have a long product life in its operational environment. Lightning protection is built into the sensor, eliminating the need for a separate surge protector. This reduces your overall equipment investment and the need to replace sensors due to power surges that may damage the sensors.
