Automation Products Sensors
Macro Sensors LVDT Position Sensors Withstand High Vibrations
Melissa Larson | June 24, 2015
Linear position sensors with standard cable and bayonet connectors often cannot withstand the high vibrations and extreme temperatures of power plants that typically operate on a 24/7 basis from 18 months to two years. Macro Sensors introduces the HPGS series hermetically sealed, high temperature LVDT linear position sensor featuring a screw-on radial connector that ensures higher sensor reliability and longer life under the high vibrations and dirty environments of nuclear, gas and steam power plants.
The screw-on radial connector of the HPGS Series LVDT sensor provides a secure connection, enabling the position sensor to withstand constant, heavy vibration resulting in increased productivity and reduced downtime for repairs. In addition, the connector offers a through-bore design that permits access to either end of the LVDT core for better mechanical support and core guidance as well as easier cleanout in dusty or dirty locations. The radial connector also gives the HPGS Series LVDTs a shorter installed length compared to units of the same range with axial connectors, enabling its use where space is limited.
Melissa Larson
