OEO Direct-Replacement LED for Metal Halide or High-Pressure Sodium Lamps
Melissa Larson | June 25, 2015
The EZ LED from OEO is a direct-replacement LED for 175W through 400W metal halide or high pressure sodium lamps. Simply by screwing the EZ LED into an existing fixture, the transition to LED technology is complete. The EZ LED requires no ballast-bypass, no rewiring, and no electrician.
Additional advantages include higher lumen maintenance, instant-on and re-strike, no color change, superior color temperature, higher color rendition index (CRI) and cooler running temperature.
EZ LED operates at temperatures ranging from -40 deg. to 150 deg. F ambient temperature. It contains no mercury, no ultra violet radiation and no infrared radiation. The EZ LED is available in “Bright”, “Brighter” and “Brightest” wattages.
