Products
ProSense Line from AutomationDirect Now Includes Flow Transmitters
Melissa Larson | June 9, 2015
AutomationDirect’s ProSense FSA Series flow transmitters monitor liquid media and provide an analog output proportional to flow rate for various flow applications. Flow transmitters are ideal for applications with rapid temperature changes or where fast response time is required, such as machine tool coolant flow, HVAC cooling water flow, and injection molding cooling water flow.
The FSA-Series transmitters sensing principle is based on differential pressure to ensure extremely fast response time (less than 10ms) and allow for precise flow measurement. Available in three flow ranges up to 27GPM, the transmitters feature a 4-20mA analog output, are fitted with a 4-pin M12 quick disconnect and are available with ¾- in. or 1-in. FNPT process connections. The integrated check valve design allows the sensor to be mounted vertically or horizontally.
Melissa Larson
