Field Mounted Temperature Transmitter from PR Electronics
Melissa Larson | July 1, 2015
PR electronics introduces the 7501, an innovative field mounted explosion- and flame-proof temperature transmitter with local operator interface for easy programming, review and diagnostics of process values in the field.
Using unique technology, the user can easily configure the transmitter from the front of the housing in any environment by simply touching the optical buttons – even when wearing gloves.
The user can also perform advanced HART programming from the front, and as a result, significantly reduce the need for handheld communicators (HHC). The easy-to-read 60 mm high definition display provides a clear indication of the process magnitude, supported by a radial bar graph in real time.
