Products
Amphenol’s High Vibration Brush Terminal Series Ideal for Harsh Environments
Melissa Larson | August 24, 2015
Amphenol Industrial Products Group now offers a revolutionary high vibration brush terminal series designed to withstand harsh environments.  By intermeshing two small wire bundles together, a superior electrical connection is made with 14 to 70 points of contact per mated pair.
The brush-like terminal technology is comprised of multiple strands of high tensile strength wire bundled together on each side of the contact and hooded for protection.  These compact size 22 signal terminals are able to accommodate up to size 16 gage cable or a PCB tail and are rated up to 5 A continuous. High-vibration brush is ideal for on-engine applications and fixed positions where high vibration fret resistance and environmental performance is critical to function.
Ideal for use in the heavy equipment, mining, medical and mass transit markets, the AHVB terminal series exhibits zero fretting and can handle up to 100,000 mating cycles. It also has low insertion forces (up to 90% lower than traditional connectors), resulting in smaller footprints, higher I/O counts and less maintenance with levers and screws.  The AHVB connection systems are rated IP67 when mated and are designed to pass SAE J2030 validation.
Melissa Larson
