Products
EXAIR’s High Lift Reversible Drum Vac Moves Liquid Farther
Melissa Larson | August 4, 2015
EXAIR’s High Lift Reversible Drum Vac is ideal for the recovery of fluids like: coolant, hydraulic oils, sludge and chips, waste water, tramp oil and liquid spills. It has been engineered to recover liquids found within below grade sumps, wells, underground tanks, pits and drains with up to 15 ft. of lift.
The powerful vacuum can fill a 55 gal. drum in just 85 sec. from 15 ft. and, with the turn of a knob, the same stainless steel pump can quickly empty the drum. Since it is powered by compressed air, it has no electric motor to wear out and has no impellers to clog. In fact, the unit has no moving parts, assuring maintenance free operation. It is designed for continuous and heavy duty applications where electric vacuums fail, and can also be used for lighter duty applications. Click here for more information.
Melissa Larson
