GP:50 NY Ltd Debuts Submersible Level Transmitter for Wastewater Monitoring
Melissa Larson | August 24, 2015
GP:50 NY Ltd (GP:50) has introduced the Model 311-M351 submersible level transmitter. The all-stainless steel construction of the 311-M351 ensures high reliability within challenging wastewater lift station monitoring applications. Its corrosion-resistant design is submersible to 1100 ft. (335 m) WC.
It is available in standard ranges from 0-10 thru 0-1100 feet WC (0-3 thru 0-335 meters WC), with custom ranges available upon request. Units are available with choice of 4-20 mA or 0-5 Vdc output, as well as an optional temperature output. The submersible level transmitter further incorporates a 3-in. diameter clog-resistant sensing diaphragm and corrosion-resistant protective baffle plate, both of which eliminate process clogging. These features also facilitate unrestricted high-accuracy level depth measurements within heavy sludge or foam conditions.
